Discuss safety valve on insert stove in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
toiletpan
can anyone please tell me where i should install the safety valve on a insert stove as the stove will be totally inclosed i know that the valve needs to be as close to the boiler as possible many thanks
Safety should not be necessary if the stove is properly plumbed using a F+ E tank.
Do not try to connect to an existing pressurised / sealed system without making the necessary changes to the system, a standard PRV is Not enough for solid fuel.
i will be connecting to a existing open system and thought a safety valve would be a extra precaution many thanks for your input
Reply to safety valve on insert stove in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
