Discuss S30 FAULT CODE ON VALLIANT ECOFIT PURE 425 in the Central Heating Forum area at PlumbersForums.net
A
aghajan
Can anyone advise how to by pass the room stat to ascertain if its faulty as fault is s30 not calling for heat. Thanks
Reply to S30 FAULT CODE ON VALLIANT ECOFIT PURE 425 in the Central Heating Forum area at PlumbersForums.net
I have a Vaillant ecofit pure, we had it installed about 6 years ago so it's not an old boiler, a new pump was also fitted at the same time...
Hello all, Just moved into a house with a Vaillant EcoFit Pure 835 boiler that is 3-4 years old but the previous owner did not bother to register...
I have a Vaillant ecoFit pure 830 which developed the f.22 fault, the pressure had dropped to 0.2 bar, i refilled the system and away it went, i...
2K
Hi everyone. Pilot light extinction problem on an old Myson Economist has been traced to a faulty overheat limit stat. It's a Ranco LM5P8037...
My Zanussi gas oven has 4 gas rings and 2 gas ovens (the smaller top oven has a grill). (Model ZCG664GNC). There are 6 gas knobs (gas taps you...
