Discuss Rothenberger rp30 problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hobo128
Just bought said product . Pressure test kit. Blanked off the end to have a go but it doesn't seem to be charging. Am I missing something.
close the brass thrumb screw
The brass screw is closed and when you say the non return valve do you mean the red leaver
Surely this can't be that difficult to work. It's just a pump. I think it might be broken
With water in the tank and the Red lever inline with the pipe does water come out of the hose?
All you need to do is close the brass thumb screw and pump to testing pressure then close red lever once you are at said testing pressure,
Leave for testing time and see if dropped
If no drop open red lever and open thumb screw to release pressure safely
If it doesn't do that unit is faulty / o rings have gone they do repair kits for these
Thumb screw below pressure gauge
Part no.21
needs water
You can buy an air test kit pretty cheap if you wanted to test with air prior to adding water!
I picked up the same rothenberger test pump a few years ago at a carboot for 5 quid, a bargain indeed but never used it yet!!?
Be careful when air testing, I think you can only test to 0.5 bar with air. Someone might correct me on this though.
no your right unless you have special permission and follow all the rules
Thought so, is it something to do with the way the air compresses when put under pressure so could do some serious damage if a joint or fitting blew?
yes just keeps compressing, give you an idea
17 litre tank pressurized to 150 psi (10 bar), the tank would store about 195 litres of air (about)
It's about stored energy. You can't compress the water you are using so pressure rises rapidly to test pressure once the system is full of water. With air you have to keep adding more and more air as the gas is compressed. This leads to a lot of stored energy and a failure on a fitting will release all the stored energy very quickly i.e. explosively.
Reply to Rothenberger rp30 problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
After some advice please. Recently bought some shower panels to have installed. However the installers must have missed installing the waterproof...
On my Valliant eco tec boiler the pressure guage is on red when cold . I drain a radiator to correct to pressure and it works fine and stays in...
Oliver1234
O
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24...
Hello, A year ago I bought the Mapei Shower waterproofing kit from B&Q, the one that comes in a bucket and has the waterproofing material and the...
A
I'm replacing the shower cartridge on my Bristan 1901 Thermostatic Exposed Dual Control Shower (Top Outlet). I have removed the cap and screw but...
AlexTTT
A
