Discuss Room thermostat options in the Central Heating Forum area at PlumbersForums.net
I have a Worcester Greenstar 30i ErP boiler with a British Gas RS2 wired room thermostat. This is what I'd like to achieve
  • I would like, if possible, to change the room thermostat to one that allows two different temperature settings i.e., a lower nighttime setting.
  • Non wireless/smart as the only significant problem would be a power cut (No networking issues), therefore a wired connection
I would appreciate any thoughts on this and recommendations for suitable replacement thermostats and ones to avoid
Eph combi pack 4 and set the off temp to what you want default is 10 dc I think
Reply to Room thermostat options in the Central Heating Forum area at PlumbersForums.net
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Hi, I just moved into a new house and it has a Glow Worm Compact 24c combi boiler and a ESI ESRTP4RF+ programmable room thermostat and I am wondering if it's worth turning on the optimum start and stop features? There is also something called TPI (chronoproportional control) but I'm not sure how...
Hi I'm having issues with my wireless Honeywell thermostat. It's sat in the living room, set at 18C currently. It makes my Worcester Greenstar 18Ri to short cycle. So, the moment it gets cold outside my boiler works for about a minute, then stops, and starts again in about 5 minutes, then...
2K
Last May had a new Greenstar 4000 boiler fitted and only recently started using the heating. Once the set room temperature is reached the boiler modulates (presumably) and stays running for very long periods (many hours) but the circulating water is only luke warm (about 35 degrees) Any heating...
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW. It all works, but unfortunately we have found that the room stats are poorly located, and so the level of control is not what it should be. We had...
