Discuss replacing soil stack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dave Walker
Hi all i am about to replace a old cast iron soil stack and was wondering what is the best way to connect it to the clay underground pipe 2012-05-13-100.jpg
thanks would you just cut the cast off at the clay or try and remove it altogether
the chances of getting the cast out of the fireclay without breaking the fireclay are slim, so have 2 options ready, one being in the post above if it comes out ok, and also have something to go from fireclay pipe to cast iron, ie timesaver etc which bolts to each pipe, you will need to cut the fireclay under the brocken socket, another way which will get me pelters but will work if you break the fireclay faucet is to fit a multikwik pan connector into the fireclay pipe then fit the cast into the other end, as long as its being covered it will work perfectly but it doesnt look brilliant
cut ,remove old stuck ! clean old cement joint and inure no debris go down ! insert new 4" plastic and re apply cement ! no need of any fittings
I'm with sgi for a second time today
Cement out.
Pipe in
Recement
Robs your mothers brother
Don't do football sorry
thanks guys i do like the idea of the 110 - 160 reducer as this will move the new soil away from the wall so i can fit some clips as i tend to find them handy
No its a simple salt glazed to pvc collar adaptor you want. if you break the salt glazed getting the cement out the collar joint, cut back salt glaze and get an external slat glaze to pvc adaptor. Most builders merchants have loads of them.
To remake joint after clearing out old cast iron. A twist of gaskin not tarred gaskin and then opc and washed sand, form a slope around adaptor for any rain water to run off.
Reply to replacing soil stack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need a quote to replace a soil stack ( cast ) in Leyton e10. The stack is already in plastic at the bottom. There also needs to be amendment to...
Hi guys, few years off doing the work but I like to plan. Can a soil stack be rerouting away from the house, over an extension roof? Reason to...
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
Hi, I live in a house that is 20yr old. There is a single soil stack running from the top floor (of three) through the first floor bathroom and...
Hi, I'm wondering if this is allowed or will work in the UK. We currently have all our waste water connecting to a single vented stack. The pipes...
