Discuss Renew outside flue terminal in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
If I’ve had a whole new flue fitted to my boiler and going outside through wall. Should the engineer fit a new outside terminal as well. Or is this not needed?
Depends if it’s ok / sound I’m guessing the reason for the new flue is rusting ?
I would say it’s fine as there’s no seals in the last / terminal end just the connecting pieces
Reply to Renew outside flue terminal in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
