Discuss Reasons for Dripping Flue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Is there an obvious cause for a dripping flue on a newly installed condensing system boiler? not constantly but enough to form a damp patch on the patio below.
It is a problem for manufacturers, from what I have seen most do it to a certain extent .
As ^^^above it should fall back to the boiler , can you see a slight “fall” backwards.
Some flues however will appear level , the “fall “ is built in to the flue .
Whos the manufacturer?
No that clued up on veissmann to be honest. But the flue pipe outside should look at least level. (The fall may be on the inner flue pipe) sometimes you can get an odd drip from the terminal but depends on a few different factors.
It does happen in colder months
You can’t always angle the flue back or rain water can get in.
Some manufacturers make a deflector for the end that can help
any pics of the flue and boiler ?
Reply to Reasons for Dripping Flue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
PSxxxxxx
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
