Discuss quad shower tray and enclosure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
buckley plumb
I don't fit many showers - anyone got tips of best way to seal the enclosure to the tray and buld the enclosure- did a lewis and cook one last wk and it was awkward to assemble the panels on my own
Bead of mastic on the back of the wall bracket before you screw to the wall and only seal the outside of the enclosure with mastic after you have finished.
Make sure you have a metal drill bit to pilot drill all your holes to hold the thing together.
I hate the flat trays - I prefer the trays with an upstand but seems none have them now - seems silly to me asking for leaks relying on siicon
Hi buckley . Its not very easy on your own your right but what i do os the base and top rails i put the screws in on there own b4 attatching the panels then take the screws out do now that theyve self tapped into the base n top rail when you come to holding it the screws fly in quicker. I always lay one glass panel on carpet and screw base rail on 1 side then screw top rail on other side then stand it up and put the screws into the top rail securing the second panel at the top which only leaves the bottom 2 screws to go. An octopus would have an easier job and when siliconing i always ONLY do round the outside - verticals and base. Hope this helps mate and makes sense.
Never done a tray with brackets, what type of tray is this guys if you dont mind me asking ? Is it for securing ones on feet ? ( with you saying u like flat ones)
All I'll say is make sure the tray is perfectly level on all sides. Don't settle for less when you put the tray in. Just making sure there's a slope to the waste isn't enough. It's got to be mint. Then the enclosure is a piece of wee wee to install.
I've done it myself where I've let the tray be a touch out and ended up making up a lot of gap with silicone right in the centre of the curve of the enclosure (one with curved doors I mean)
It's all about foundations. The rest is superficial in my opinion
Definitely dont want 4 upstands. Ive ripped a few out, customers sick of all the muck and cack that sits between upstand and enclosure.
Just looked at the link and looks a terrible idea, ive never fitted one, cant uderstand why they would need an upstand, im defo with you guys on the flat ones, anyway we become the masters of neat silicone beeds , DONT USE CHEAP CRAP SILICONE,
USE CHEAP GOOD SILICONE hehe and you will get a nice neat seal,
Reply to quad shower tray and enclosure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning...
Hi guys, new to this forum, was looking for advice regarding a mira flight shower tray i've just installed [diy]. After installing it, and then...
2K
Hi I'm currently doing the pre-planning for my next DIY project fitting a shower tray and enclosure from scratch. I'm confident of being able to...
Hi I had to remove the glass panels from this quadrant shower cubicle and I'm struggling to get one of the screens back in place properly. The...
Hi all, I've got a new customer who wants a bathroom fitting. This would include a shower tray, and shower panel being situated partly across a...
