Discuss Pipework for downstairs radiators on new builds in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ok, is there a way of first fixing the downstairs rads in 15mm (without loads of boxing ins) if the ground floor is a solid floor so can't do one drop then go under the floor to feed the rads.
we used to do 10mm downstairs and 8mm upstairs off manifolds on the landing, if your going to go behind dot and dab, do it before they put the boards on, its so much easier than chasing and chiselling the dabs then replastering!!
thought so 15mm un-chased in is too much to dot and dab over?
i like the word used to no one should be using 8mm these days for heating circuits/ runs to rads
theres no reason ytou couldnt use 8mm but its a lot of trouble using two sizes just do it all in 10mm of manifolds
So if it's done all in 10mm copper how do you bring the pipes out to the radiators? Sorry for all the questions have usually just fed the first floor rads in 15 from below, as down stairs has had underfloor heating.
Reply to Pipework for downstairs radiators on new builds in the Plumbing Jobs | The Job-board area at PlumbersForums.net
