Discuss phoenix TRV 15 mm rubber olive compression joint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
butlerps
Hey guys,
has anyone ever come across a rubber olive before? Every valve I've ever fitted up until now has a copper/brass olive compression joint onto 15mm pipe but this new radiator valve that I need to use for the type of radiator I have uses rubber olives to compress onto the 15mm pipe.
I've contacted phoenix radiators but they have offered no support regarding supply of spares/manufacturer/supplier etc.
I want to at least have a hand full of spares in my box just in case.
Anyone know where I can buy them from?
Cheers,
Who did you buy the valve from? I would expect your supplier to be able to source spares on a product range they sell.
So what grabs or holds the pipe into the valve.
Most connectors squash into the pipe, holding the pipe in the fitting and valve.
Are they relying on the pipe being fixed solid and the radiator fixed so that the pipe cannot become dislodged?
I would be looking at not using these valves unless you can secure the pipe into the fitting with another method other than compressed rubber olive.
It may hold with cold water ( may ) - will it hold with heating hot water going through it?
The rad valves on my towel rail at home came with plastic olives. Was very dubious, so pressurised it to 5 bar and not even a weep.
I bought the valves from Ryansdirect however decided to contact the manufacturer Phoenixradiators. Their customer support was polite but offered no help "thank you for your enquiry, I'm afraid we do not retail spare parts. I believe they are generic parts so perhaps your local DIY store or B&Q could supply these to you". Very disappointing as I can't believe I'm the first one to ask them the question.
I've no doubt they seal well (plenty of radiator valves/plastic pipe fitting rely on rubber seals) but I'm not happy installing them without having any spares.
Sounds like you got the 'Polite' - Fob off.
If someone 'fobs' me off saying parts are generic when they are not, they don't get a 'return Fob off', they get a hell of a lot more than that.
Some manufacturers don't sell to the public, that's why the best place to start would be your supplier and if they don't or can't supply spares I'd want my money back!
Reply to phoenix TRV 15 mm rubber olive compression joint in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
I have Honeywell Valencia TRVs 10mm pipe size, I’m making mods to accommodate larger rads and it looks like the 10mm compression insert is special...
  • Solved
Hi There, I want to swap out my old valves for TRVs but the threads are different sizes, and I'm unsure how to resolve it. My current existing...
2K
Daley power
M
Hope this is in the right forum. We've a utility room radiator with 10mm pipework; fitted about 6 years ago it has a BOSS TRV which has failed...
3K
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
