Discuss Peugeot Expert Van in the Plumbing Jobs | The Job-board area at PlumbersForums.net
markadams
I am looking for another van, I currently have an 06 Peugeot Partner 2.0 and I am finding it too small.
Does anyone have an expert van they can measure the space in the back so I can see the difference.
I hoping to get a 2.0 version about a 2013/2014 if I can ever find one, they seem to be in very short supply.
What is your opinion on them?
Mark.
I don't really want something as big as a transit. The expert is between what I have and a transit size.
Peugeot Expert, Citroen Dispatch and Fiat Scudo are all the same van with different badges. Looking for one myself. I'm after the long wheelbase model with 2.0l motor. There are a few on Ebay up and down the country both private and dealers
Reply to Peugeot Expert Van in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I was sent an engineer by Ideal Heating to fix a problem with my system. When he left he drove over a pot of sealing compound (which must have dropped out of his van) on my shared drive. My neighbour pointed it out to me since he was parked in her space. I tried to remove it with water and...
In short: Do suppliers sometimes list BSPT as BSP? I need a tee, 22mm each end with a BSPT in the middle for an expansion vessel to dangle from. Why I think its I've used calipers on the threads and counted them, and the male end sticking out of the vessel is BSPT 3/4 with 14 threads per inch...
We have just moved in to a 1934 Semi- and I am getting round a few simple DIY tasks, including a couple of plumbing-part renewals such as modern pipe/u-bend/fittings to kitchen sink, rinse sink etc as preventative maintenance! Nothing complex or specialist, that's for you expert guys! But in...
Background I have a small one-bedroom flat in the roof space in a victorian house. There are three floors below and each floor has a single one-bedroom flat. The mains pipe bringing water into my top-floor flat is 15mm copper pipe. There is a water meter in the flat and a stop valve. There is...
Hi All After having pooling water on my drive, I dug down around to find: Black pipe poly/plastic dug 450mm deep spraying water at mains pressure from small hole/crack The outside of pipe (measured with veneer caliper) at 23.5mm Pipe Runs under drive, along side of property and looks to go...
