Discuss part p in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
adrianfs1
hi guys just wandering do any of you guys have the part p cert, you must need it for fitting showers. cheers.
I do but I still get an electrician in. (My electrician can do plumbing but he still gets his plumber in!)
dont need an electrician to change a shower - but if its a new one going in then i get a spark in - you can spend an awful lot trying to get every qualification going matey - but in the long run its better to specialise in one trade - than be jack of all
part p relates to electrical installations, this includes electric showers believe it or not, as i said currently do it myself and get sparky to sign off after hes made all the checks, however this can delay finishing job as he is also a very busy man.
installing a shower - but like for like is not part p is it ? im probably mistaken haha. yeah running the cable from fuse box is part p - but i didnt think taking shower off wall and fitting a new one was - i thought that was in our scope of works
i'd quite like a definitve answer on this. i suspect you technically need part p for it but few bother.
full central heating wiring systems require you to be part p
well thats shocked me also - i only completed my level 3 last year and my tutor who is also 17th edition qualified - told us that we only needed part p if we had to go into the ring main - i can wire to a fused spur and also do my own central heating wiring as long as i didnt interupt the ring main according to him?
I thought it was best practice to have the central heating on a seperate circuit on it's own. Confusion reigns!! All I know for certain is that if you qualify for the full blown Part P none of this stuff affects you.
Reply to part p in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is...
I have been given a quote to fix a noisy tap. Apparently they have to “replace breech to main shower” — which I understand to mean the thing...
Hi everyone. I'm currently working on a job for a customer. their radiators are not all heating up. in total there is 12 radiators. 4 of these are...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
