Discuss Overflow head scratcher ! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bung the cold feed temporarily if you want to watch it come over the vent!
First thing I'd look for is to check mixing valves for stuck check valves, only takes a slight weep through if you've got mains on one side and tank on the other. As for overflow coming up expansion pipe, won't happen unless you've got a lot of pressure blasting it up! :smile5:
Reply to Overflow head scratcher ! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering...
