Discuss Overflow head scratcher ! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Gez2312
Hi, been to a customers house tonight .
Overflow running from domestic tank , took a ball tap - thought I already knew the problem!
Ball tap tap is working fine , submersed under water
ran some hot water off , level in tank dropped .
Bent arm arm down on ball tap , it shut off around 3" below overflow (cylinder was hot)
Checked cylinder stay and zone valve operation.
Heating system is sealed, and is holding pressure so think coil is not split
water in in header tank is tepid , and cold fill pipe to cylinder (a floor below) is warm
nothing from expansion , if it was back flow from somewhere surely it would come over expansion , not push water in cylinder up feed pipe?
Sctraching my my head now, maybe just missing something simple ! Any ideas gratefully received , I used to think I was quite clever !
Your mains is more than likely back feeding somewhere. .last time i had one of these over flow mystery it was a dodgy kitchen mixer tap sending the main water up the hot
Is there an unbalanced mixer tap/shower somewhere that hasn't got non return valves fitted, could be passing back up hot dist pipe
edit
posted same time as oily, didn't copy honest
But surely in would run out of expansion pipe rather than into cylinder and lift the weight of water up the cold feed ?
I've had the dodgy kitchen tap scenario on a combi before, that had , had everything relplaced for poor hot water first !
If it was a steady run from expansion I could understand it ! But I'm head scratching at this one!
Customer says only difference to usual is hot water has been on constant rather than timed due to guest staying
Maybe that guest is using a bathroom or shower that has not been used for ages / faulty shower mixer?
Yeah that could be the case , bloody trouble causing guests!
But why hot water back up feed pipe and not just cold running from expansion ?
It will come up the feed pipe into the tank. Seen this before. You can watch the haze in the water if you shine a torch on the bottom connection inside the tank.
Usually a monobloc tap is the culprit I find
Will have to go and investigate further but it's quite and old fashioned house , and from what I can remember all taps are either separate or old school full turn type mixers, not these modern ceramic mixer ****e !j
Will have to go and investigate further but it's quite and old fashioned house , and from what I can remember all taps are either separate or old school full turn type mixers, not these modern ceramic mixer :nono: !
the water in the system will rise uniformly up the cold feed and the vent pipe, but it will reach the the water level in the cwsc before it will go over the top of the vent hence why its not coming out of the vent!
Bung the cold feed temporarily if you want to watch it come over the vent!
First thing I'd look for is to check mixing valves for stuck check valves, only takes a slight weep through if you've got mains on one side and tank on the other. As for overflow coming up expansion pipe, won't happen unless you've got a lot of pressure blasting it up! :smile5:
Reply to Overflow head scratcher ! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked overflow/expansion pipe. Hence the header tank then reaches the overflow level and the overflow trickles out. I have changed the ball valve washers thinking it was...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are about to upgrade the upstairs bathroom and are considering installing a shower bath. My concern is that although there is more than sufficient...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
Hi, I've got a cold water storage tank which feeds the hot water cylinder below. The hot water is backflowing up to the cold water tank and then overflowing now and again. If i put a non return valve on the cold feed to the cylinder would this just push the water up to the vent pipe? There are...
Deleted member 120897
