Custard went off on holiday, came back boiler didn't fire up.
EA code, reset -nothing. Called me, got there, checked for gas, checked condensate pump ok, took cover off to check ignition and the flame rectification lead was disconnected? How would this happen?
Any clues? igotnoidea
DIDN'T check!! I didn't *work* on the boiler before then, only opened up case and found lead disconnected~ THO' they recently had boiler serviced by another company, the landlord has a contract with-details not known to me.. maybe they didn't put the lead back properly IF they even took it off to service?
Reply to odd one, worcester greenstar, 40CDi, classic, regular in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a worcester greenstar 30 CDi Classic regular.
The central heating is working fine but the water is not heating.
If i put the system off for about 10 mins and start it up again it still does not heat the water.
I am not getting an error code.
Where do I start?
thanks
teslacar (BTW...
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the existing boiler needed upgrading. The Mechanical Engineers advising the architect insisted that we had a conventional cast iron combustion chamber boiler...
Hi
Can anyone help?
I've got a problem with an intermittent EA fault on a Worcester Greenstar 38CDi Classic GC 47-406-38. I was called out to it but couldn't get it to go to fault- each time it fired up however, on a video the customer took he kept having to reset it.
I checked the gas rate...
My Worcester Greenstar 29 CDI boiler made a loud bang earlier today, and has now stopped working.
It is flashing the 'EA' error code, which according to the manual, means no flame is being detected.
I tried resetting the boiler a couple of times but upon doing so, it just makes an extremely...
Hi Folks,
I have a puzzling issue that I hope someone could help diagnose.
The mother-in-law has a Greenstar 34DCI Classic that has worked fine for ~7 years (without a service ). Recently it has been intermittently cutting out and requiring a reset and displaying an "EA" error message on the...
