Discuss No water flow into cistern in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
A
Alan from Aberdeen
Hi
I have a Dudley vantage dual flush pneumatic Niagara flush valve system.
The cistern is not refilling after a flush. The system has never been good - refilling very very slowly but now not even doing this.
I can turn on /off the cold water tap on the bath which is situated next to the cistern and the water will start to fill the cistern albeit very slowly.
Any idea what could be wrong?.
Inlet valve needs servicing/replacing, it is a Dudley Hydroflo in these - the design has changed slightly so that the float is now a shrouded one. The old ones suffer from the adjustable cork screw float arm going soft and bendy and not shutting off properly.
You may find the arm on yours is stuck up in the air and will fill if you knock it down- but it will keep happening so service/replace anyway.
Reply to No water flow into cistern in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
A
My Dudley vantage pneumatic operated niagara dual flush valve is not refilling into the cistern and if it does it is very very slow. I can turn...
Alan from Aberdeen
A
Hi there, I’m hoping someone can help me with this problem please. I’ve searched for similar posts but not found anything helpful! My mum’s...
Hi, I have just installed a combination all in one WC/small basin…. Out of the fill valve there is a small tube which emits a lot of water...
Suddenly my downstairs toilet stopped filling this week, I suspected a blockage in the filter or cistern itself, however after removal of...
