Discuss Motorised valve - How can I control it manually? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tonyrey
I have a three way motorised valve minus the motor and actuator). I'd be very grateful if anyone can tell me the positions of the control to turn off rads or hot water - or both. It's a Worcester 420302 PMV3 (replacement MPE322)
How to control motorised valve?
I have a Worcester 3-way 420302 pmv3 (replacement MPE322) - minus the motor and actuator. I'd be very grateful if you can tell me which positions are needed to turn off the rads or HW.
Re: How to control motorised valve?
I know where the pipes go but not the positions of the valve control. There's no indication of which direction the water is flowing.
the one into the cylinder is hot water, work it out from there.
I'm obviously not very good at explaining myself! I don't know which positions the shaft operated by the motor should be in.
Can you post a pic Tonyrev? Never heard of a worcester 3 way but they all work with the same principle I'd think anyways :26:
I studied in Newcastle way back in the fifties and found the Geordies very warm and homely...
It's not very good but you can probably see the semicircular shaft in the centre. The pipe above is to the pump, on the right to the cylinder and on the left to the rads. I hope that's clear - and thanks for your
interest. :yesnod:
Looks like a danfoss hsa3. If the heads knackered it might not even switch on the boiler. Treat yourself to a new head or a call to somebody to fix it.
The actuator will only go on one way does it not? Two holes match up with the two fix's in the valve plate? Offer the actuator to the plate and look to see where the flat pard of the 'D' hole is. Move the shaft to suite yeh?
Reply to Motorised valve - How can I control it manually? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a 4 zone / 7 loop UFH system. 2 zones (4 loops) always get hot when the system is on when the zone thermostats and actuators are...
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
Looking for a quick bit of advice since I'm trying to wrap my head around what work I need done. Right now I have an old conventional boiler...
