Discuss Mono Basin Mixer Tap Problem Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Stealth
Hi
I'm just a DIY'er popping over from the tiler forum.
I've got problem trying to fit a basin mixer monoblock type tap. The tap is connected by using 2 x 10mm flexible tap tails. The problem I have is that the tails go right into the body of the tap so I'm finding it impossible to tighten the hex part of the tail because I cannot get a spanner/wrench on it!
I've tightened the tails as much as possible by hand but both tails are leaking from the rubber washer at the top of the tail.
Has anyone got any idea how I can remedy this problem? It's getting to the stage where I may have to take the tap back and look for something else with an easier connection, which would be a shame as I like the tap.
Any ideas appreciated
Hi Sheath
Welcome to the plumbing forums
The joint on the tails is made when you screw the ends into the tap,the rubber 'o' ring seals against the side on the tap housing as it is screwed in,so even when hand tight should not leak,we tighten a bit to stop it from maybe coming loose but not needed
If leaking then rubber 'o' ring must be damaged or tap housing distorted,probably former,are taps low cost,if so ,maybe better getting separate better quality flexi's or copper tails,which you can do from merchant
make sure no grout ect gets on rubber 'o' ring or in tap as could damage rubber when threading in
imho
a good nip with your hands normally does the trick.
i have a question on the same type of tap. mine is leaking from the swivel head when turned on, i presume these are ceramic disk type taps but ive never split one down. are they easily fixable?
Hi fuzzy
There is another "o" ring in swivel section,spout comes off,either grub screw at rear or place spout sideways,usually to left,inline with tap head and it just pulls out
once out,'o' ring on spout end,replace,and silicon grease tap body,or remove 'o' ring and rap ptfe tap round recess twice round only,replace 'o' ring,grease,should be ok as long as 'o' only worn ,not damaged
cheers mate, will have a look at it this week when i get chance
Hi
Hi there,What make are the taps, obviously not a name brand, can you fit the flex to the tap first before fitting it to the block :D
Thanks for all the replies.
Had another go today. Took the tails off and refitted as tightly as I could by hand and the leak has gone. Very relieved!
Glad to hear you got it sorted, but I'm still trying to work out the type of taps and that was only the thought that had came to mined..
Keep up the good work there pal
Hi there from what it looks like a the cylinder is placed a horizontal distance from the cwsc and this is going to take longer to replenish.""
What is the size of the pipe from the cwsc to re-fil the cylinder??
puddle, did u mean the spout? if so its not that type, it has a swivel head for h/c and on/off like a shower mixer. i cannot see any grub screw like the ones u get on kitchen sinks with a swivell spout.
Sorry,if swivel head type,you may be able to get a service kit but probably require and best to fit a new cartridge,what make are they
If a round chrome barrel,round arm comes out of swivel head for operation,this usually unscrews and grub screw under that,undo,replace cartridge :)
think were talking about the same thing now thanks puddle. i havnt had a close look but i didnt see a grub screw, although i know they're that small ther're hard to see sometimes.
it may be easier to take out the cartridge and take it to a merchants, who stocks em? my local plumbers wont, what about plumb centre?
Reply to Mono Basin Mixer Tap Problem Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
