Discuss Mixing metals on compression fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Annoyingly I have used a copper nut on a steel isolation valve and the corresponding steel nut on a compression copper fitting (15mm). Should I dismantle and redo? I will have to buy a length of plastic pipe and new olives as well as drain system. Or will it be OK?
The fitting was from screwfix described as brass, steel and plastic.
https://www.NoLinkingToThis/c/heati...p=managedredirect-_-plumbing-_-isolatingvalve
I attach two photos. Thanks for help so far
The ones with the extra blue o ring eg the super seal ones ?
Reply to Mixing metals on compression fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
