Discuss Megaflow 3 bar pressure reducing valve placement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have lived in our house for around 10 years and always had bad pressure if more than one tap is running, toilet is flushed etc(hot and cold). We have (what I believe to be) a mains pressure system with a non vented Megaflow cylinder.
We are about to install a new thermostatic shower and mentioned this to the plumber. He had a good look for us and concluded that the Megaflow pressure reducing valve has been placed in the wrong position. Its currently right after our stopcock as the water enters the house. He has quoted us to move this to the correct position to where the cold supply enters our Megaflow in our airing cupboard. Does this sound likely? and the right thing to do?
He's right in one way but still legal and correct (just after main stop tap )
Any chance of a pic of your unvented cylinder??
Also before he does anything regarding the cylinder make sure he's G3 registered (unvented cylinder qualified)
Here you go. Hopefully its clear enough. When the plumber tested our flow rate, it was approx 8 litres a minute, when the toilet was flushed(downstairs) the kitchen tap right next to the house inlet dropped to around 5 litres a minute.
That's great and there's your problem an unvented cylinder requires 2 bar and 20 lpm min else you will have problems like your having
Now the pressure reducing valve may be at fault and causing you to have a reduced flow rate, best to get your plumber to test the flow rate before the pressure reducing valve
Thanks Shaun, Our water into the house literally goes into a stopcock and then 15cms later the pressure reducing valve, so not to easy to test the pressure and flowrate before, but it does sound like him moving/replacing the valve is a good plan?
Lee.
Lee.
If it's at fault then replacement sounds ok as for moving if it complies with regs don't see any point, makes sure all taps are balanced etc
Do you know what size pipe and material you having coming in ?
Also best to cap the open end after the ISO valve on the hot
The house was built 10 years ago, so its all relatively new. If I look where the stopcock come up from the floor, I`m sure its a blue hose type presentation(hope that makes sense)
Yep that's alk will be either 20 or 25
May be a silly question is the stop tap open all the way open ?
It is, its one of the things we tested. The Pressure reducing value plastic handle has snapped off, so we have to use a pair of pliers to adjust it, but the plumber was sure both were fully open.
Its probably also worth mentioning we have a water softener also connected right after the PRV, however when we bypass this, it does not seem to make any difference in the pressure we get(if so its very small)
I would get your plumber to remove the valve and get a temporary piece of copper pipe and test the flow into a bucket least you know if it's the reducing valve at fault
Just an update on this one. The Plumber moved the pressure reducing valve to the cold feed supply upstairs on the megaflow and it fixed the issue!!! Can now run two showers, flush the loo with minimal drop in pressure(it is noticeable but no where near as bad). Don`t understand the logic as to why, but happy its fixed.
Lee.
Reply to Megaflow 3 bar pressure reducing valve placement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
