Discuss Megaflo Heatrae Sadia Immersion Heater Replacement TSE v TSR in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I know this topic may already have been covered but I just wanted to address it again.
Can someone please tell me what the difference is between the teal green thermostat and the white one? (see attached photos)
I have one of each in our Megaflow, one operates the Economy 10 and the other is the override and is switched on as and when more hot water is required. I am looking to buy some spares and need to know if need to buy like for like or if they a one of the same.
I just noticed while posting this, one is a “Type TSE” while the other is a “Type TSR”
heatrae-sadia-thermostat-white-jpg.287812
heatrae-sadia-thermostat-green-jpg.287811
Reply to Megaflo Heatrae Sadia Immersion Heater Replacement TSE v TSR in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi everyone I have a 20 year old Megaflo CL250 indirect hot water tank that I typically heat with an oil-fired boiler. It has locations for two...
2K
Heno here. From Ireland. I'm a marine sparks but that doesn't qualify in any way to deal with electric and water. Pleasure to meet you all. I know...
2K
Dear All, My hot water cylinder (approx 45 years old) is fitted with a bottom mounted immersion heater controlled via a timer and an Essentials 7"...
5K
An easy one... The power cable from my immersion heater controller to the heater itself needs replacing. It's been stripped back so many times...
4K
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
