Discuss Makita batterys in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Koogatubac
Just had to buy new 18v 3.0 lit battery from amazon since my other 1 packed in.
What should i do with the broken one? Should i complain to amazon and say its faulty thats came or will they know by the serial numbers? Lol
Contact Makita. If it has been charged less than a certain amount of times they will repair or replace it for free. Apparently they can test it and see how many charges it has had if you send it off to them. A mate of mine done this a got a new battery.
Slightly off topic do we know if the 4.0A Hr batteries are any better in terms of failure rates?
if not,hire one out from a hire shop,change it for your duff one and go in and start shouting
Thanks for replys. Mike - i thought this would happen, damn! Lol, mgfs - ive had the battery for roughly 4 yrs lol think ive got the most of it. Sheff paul - i thought of doing something like this.
My boss has all makita gear, im thinking of swapping a battery for my duff 1. Haha however we rarely work together damn!
That's why it's a good idea never to work with someone who has the same make of power tool as you. When I was on Iguana we all had makita rechargeable drills and if you worked with one guy you always had to check your batteries for charge. If his battery ran out he would just swap it for the fully charged one in your box so on the next job when yours ran out and you went to get the spare it was flat.
lithium cells lose capacity/ degenerate over time with or without use. So the number of charges is not the only reason why they lose capacity.
i have several milwaukee 28v batterys that charge fine but hold little charge. a few have not been used much but have still lost capacity due to age.
I did 2 weeks of working with him and once we got put on seperate jobs thats when my battery wouldnt charge and found out it was goosed! Looks like your right mike. Think hes swapped his duff 1 for mine lol
One of the reasons it's important to record the serial numbers of your tools and mark them.
This is one of the reasons I've gone DeWalt instead of Makita. All the guys I work with have Makita powertools and are constantly sorting out the batteries. It's not too bad for them though as even though we all share the tools, they are actually owned by my boss and his dad, just shared between the different companies he runs.
Reply to Makita batterys in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Sorry I can't find my original first post which stated the problem I had with a plumber. To update you all he finally admitted fault and came...
2K
Hi gents and ladies, Making the probable mistake of buying a house at present : bit of a fixer with a shoddy but recent boiler installation...
My kitchen radiator is filling with hot water despite my TRV being set to 0. It's blazing at maximum. This goes for the rad when I try two...
2K
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
