buckley plumb
was called to inspect a barn conversion where the mains had been taken from stoptap to cylinder cpboard and lagged up to there but then it come out of the cylinder cupboard to all the cold taps including kitchen tap unlagged. the problem is the pipe runs in the floor void with the under floor htg.the customer is complaining of warm cold water untill he emties the water in the section under the floor.what are the rules for drinking supply water .i thought it was you were allowed to run tap to purge for 1 minute then test temp and if less than 20degrees then its ok. am i right
thanks ant
thanks ant
