Discuss Mains HE boiler help in the USA area at PlumbersForums.net
I’m struggling to locate the stopcock in my flat and I need to isolate the boiler so I can swap a bath tap over. Can I isolate it from the water feed on one of the inlets on my boiler? I’ve attached a pic. It’s a Main Combi 24 HE.
All my cold taps can be isolated individually but my hot taps can’t be (typical) so any help is appreciated!
I’ve checked behind the panel and no joy. So if I turn that valve then no water coming at me while I swap the tap. Thanks for your help!
Wouldn’t turn the boiler one off as chances are it will leak afterwards and it won’t turn the cold off
under the kitchen sink ? Downstairs toilet ?
Reply to Mains HE boiler help in the USA area at PlumbersForums.net
Hello I’m hoping for some perceptive / input as I’m a long-distance landlord trying to unpick the best thing to do. Gas safety certificate was...
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
Hi there, I’m hoping someone can help me with this problem please. I’ve searched for similar posts but not found anything helpful! My mum’s...
Hi all, thank you so much in advance for any help. I’m always really grateful for the advice and support from experts when I have been on here a...
1K
