Discuss low water pressure shower head in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
1. The head requires a minimum 0.5 bar pressure.
2. If you have a tank fed system, and the shower head is in the room below the cold water storage cistern your head of pressure is likely to be less than 0.1 bar. 1 bar equates roughly to 10 metres of height.
3. Probably the cheapest option is to install a shower pump. Expect to pay £400 to £800 for the pump and installation. It's not simple and depends on how pipes can be run.
I can't find a specification for the flow-rate for that head, but your current plumbing's capacity to deliver a many litres per minute (presumably at a dynamic pressure of 0.5bar) may be the limiting factor.
Thanks for the help, Really appreciated
Reply to low water pressure shower head in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I have a brand new, unboxed shower/wet room screen from KRION purchased from Porcelanosa UK. It is the Attica 1 model, as shown in the attached...
Sebastian T
