Discuss Loud humming sound fron hot water cylinder and supply pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dom38
HI, WAS WOUNDERING IF ANY ONE COULD HELP ME , I HAVE A LOUD HIGH PITCHED SOUND COMING FROM MY HOT WATER SUPPLY PIPE FROM THE HOT WATER CYLINDER , IT IS NOT CONSTANT ! WHEN YOU TOUCH THE PIPE YOU CAN FEEL IT VIBRATE . THIS SOUND IS HAPPENING WHEN THE TAPS ARE OF AND THE BOILER IS NOT FIRED UP ALOUGTH THE CYLINDER AND PIPES ARE HOT .:teeth_smile:
Hi sorry should have stated that it was vented
Had numerous occasions where this has happened in the past Dom38.
You say the noise only happens when NOTHING is being used? Is the immersion on?
:iagree: Check the immersion switch hasn't been accidentally switched on.
hi thanks to you all will check the immersion is not swiched on ! but why would this cause a problem the thermostat should cut the heat from the immersion ! thanks again :28:
yep ! but my head is sore! i am of to the pub hope there pumps are working !
the cylinder stat doesn't control the immersion, it is on a separate control circuit and independantly powered
Hello well thanks for all your advice but I am afraid to say the problem is still occurring the immersion has beem totally isolated . does any one out there have any Outher ideas ?:17:
Reply to Loud humming sound fron hot water cylinder and supply pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app...
