Discuss Leaking valve on boiler piping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
TanyaB
Hello - Could anybody identify what this valve is please. It has started leaking a lot and is on the hot water pipe coming out of the boiler, which is Boulter Economy standard oil boiler, vented system. It has a nut on top that was half a turn undone so I tightened it hoping it would stop. It hasn't.
Thankyou
I would rather put a proper 3bar PRV on.
Those relief valves, as in photo are just tightened up on their adjustment nut to a guessed tightness for the pressure blow off.
The O ring seal in them just perishes with heat
I agree, them things are awful.
Yes, everything is so wrong about them! If they ever did open under pressure I bet they would fail to seal again at all and flood the place.
I remember it was obviously a cost thing, - at least about 4 times the price between a 1/2" valve like that and a proper 3bar valve.
I don't think I have ever seen a PRV opening due to a boiler being over pressured when frozen pipes, or in fact any vent/feed blocked.
Reply to Leaking valve on boiler piping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
Hello The heating side of my Ariston Combi A23 has stopped working since a new 3 way valve has been installed. It's been a hugely reliable boiler...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
