K
KevininGlasgow
Hello there
I am a new member and really need a bit of expert advice, the waste pipes from the bathroom sink and bath
joint up into 1 outflow pipe which is in a reducer/insert going into a 6" cast iron pipe which protrudes from the masonry wall by about 2 inches. There is a seepage/leak around the 6" pipe.
I removed the 2" plastic pipe that is going into the reducer and replaced it with a longer length of pipe hoping that the longer legth inserted into reducer would pass over any leak/break but it is still leaking.
ANY INFO IDEAS WOULD BE GREATLY APPRECIATED
THANK YOU
KevininGlasgow
THANK YOU
KevininGlasgow
