A
audievo
Ok so have a water leak in a pipe in a concrete floor.
Insurance sent a guy out who said there was a loose connection on the stopcock.
Tightened it but not solved
Next guy says it is the water main, he can here it leaking and need a new water main £1000?????
Now if that's what's needed so be it but...... when I listened to the hissing noise I wondered if it was before or after the stopcock.
I have found that when I turn the water off at the stopcock the hissing stops.
Am I right in thinking this means the leak is not the main pipe before the stopcock but a pipe after the stopcock.
There is a pipe buried in the floor which feeds the sink at the other end of the kitchen.
It would be a lot easier to re route the pipe to the sink by cutting before it disappears into the floor then surface mounting new pipe and reconnecting where it emerges as all pipes could be hidden under kitchen units.
Any help welcomed cheers
