Discuss Leak in concrete floor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
audievo
Ok so have a water leak in a pipe in a concrete floor.
Insurance sent a guy out who said there was a loose connection on the stopcock.
Tightened it but not solved
Next guy says it is the water main, he can here it leaking and need a new water main £1000?????
Now if that's what's needed so be it but...... when I listened to the hissing noise I wondered if it was before or after the stopcock.
I have found that when I turn the water off at the stopcock the hissing stops.
Am I right in thinking this means the leak is not the main pipe before the stopcock but a pipe after the stopcock.
There is a pipe buried in the floor which feeds the sink at the other end of the kitchen.
It would be a lot easier to re route the pipe to the sink by cutting before it disappears into the floor then surface mounting new pipe and reconnecting where it emerges as all pipes could be hidden under kitchen units.
Any help welcomed cheers
It's your house and if this is the permanent repair you feel is best for you then go for it.
Sorry mustn't have explained properly
There are two pipes and I'm not sure which one is leaking.
The main pipe coming into the house
or
The pipe running under the floor to the kitchen tap.
they are quite close together in the same general area of the floor.
I can hear a hissing noise from under the kitchen unit which could be either of the pipes.
However when I turn off the stopcock the noise stops.
I am thinking that if it was the main pipe leading from outside then would it not still be leaking/hissing weather on or off?
whereas if it is the sink pipe then when I turn off the stopcock it would not leak as the supply would be stopped.
So if the pipe coming into the house were leaking before the stopcock surely I would hear it leak weather the water was on or off.
thanks
you've answered your own question. you turn the main water off and it stops.
I had the same scenario this last week.
water leak under a kitchen floor.
heating was holding pressure- not that.
Isolate hot water at combi, still hear the hissing.
Isolate cold stop tap, hissing stops water meter stops moving.
diagnosis - leak on cold pipe.
didnt want to dig the floor to try and repair because there was evidence of corrosion on most pipes coming up from floor, some radiator pipes rerouted presumably when going pressurised.
cold, hot and heating pipes all running in same space, so I decided to just reroute the cold to avoid disturbing anything.
get that done, turn water back on - hissing noise still there!
proper fed up now, decided to dig the floor up in the end.
2 leaks, hot and cold were so tight together they had rubbed through and were both leaking!
pipes everywhere, managed after a lot of struggling to to cut out the redundant cold pipe and replace a small section of the hot.
hopefully your problem is more straight forward, don't lose any sleep over it.:grin:
Done simmilar job 2 weeks ago ! Customer had a one of them searching with sounds tracing to confirm leak as they could afford it !
I ended up with 2 visits and re run pipe in kitchen all the way behind kitchen units : total cost £820
Ok thanks for the replies
If it turns out to be the main pipe can this be repaired or does the whole pipe need changing from house to street.
I will try to re route the pipe I'm hoping it is.
Also, are these leak detection companies any good and what do they charge?
Leak detecting company that was used all they did is confirmed what I did diagnose already ! customer was rich and did one seconded opinion ! In my eyes was waist of money . Don't know how much they charge but I am sure it will be more then £400 as they send engineer that is booked for a day on that job !
It depend on lay out of the house , I will suggest to renew only the part where is the concreted floor ! Good luck
If any of the supply pipework is lead, now would be an ideal opportunity to replace it.
The long & sort is, follow the Water Regs don't install pipework that will not be accessible in the future !!
It is there to save all this heartache.
Reply to Leak in concrete floor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
