Discuss Large waste needed for reconditioned cast iron bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DanMac
In a bit of a bind. Spent money reconditioning a lovely old cast iron bath but really struggling to get a waste to fit nicely in the recess. The hole itself is 70mm but the total diameter including recess is 95mm. The largest belfast sink waste has a wide flange that takes it to 85mm but the plumber has warned that the 5mm around the rim will hold water and go stagnant and mouldy etc. We can't use a shower waste because then we cannot use it as a bath and I am hesitant to use a basket sink drainer type waste as it could be a hazard for kids trapping toes in it etc.
Plumber suppliers all tell me to look online but I am getting no where. Any ideas?
I don't suppose you still have the old one ?
If not 2 choices
1. Have one made up as per PriestyUK but I would use brass as it is easy worked & can be plated to match taps.
2. Put in the biggest one you can find, if it is only 5mm around then use a white filler or washer in the gap if you are not confident in using an epoxy type one try a good quality silicon but mask it all up first so you just do the gap & don't make it flush. Scan10016.jpg
I had these ones made up for Ringo's (name dropper) place in London, the original glass basin before every one had them.
What a mere they were to have plated "nickel blow" took a couple of goes to get rid of.
Please register with us and start a new thread to receive additional answers to your question.
Reply to Large waste needed for reconditioned cast iron bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am replumbing my lakeside hunting cabin (totally off grid, water from a well or the lake, solar power through a battery bank and now a large...
2K
The customer dosen't want to change the cast iron bath but it has rust around the plug waste hole. It dosent look good and is difficult to clean...
2K
Welder
W
  • Locked
Hi I'm working on a bathroom with some unusual stuff. They picked up an old basin, belfast ceramic style, small about half the size of a...
3K
  • Locked
Hi hope you guys can help...... I'm fitting a new bathroom suite and shower, but i have concrete floors. My old shower tray was sitting on an...
3K
broontroot
  • Locked
I have been to a job today where there is a 4" cast iron soil stack with a 3" branch, running inside a boxing inside the property. The person who...
2K
bobpape
