Discuss kiychen jig routing video in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Hey fellers, I am installing a kitchen and need to rout the work top in. I have never done this before but I remember someone posting a demonstration video for the jig. Anyone remember what thread it was?
personaly would NEVER attemp this myself! it takes a good joiner around 2 hours to do a good corner apparantley! imagine if you do a mistake? must be some vids on youtude tho! remember to price in a router bit in the job as it wont do many joints
Me either. Seen far too many mitres that are blowing up/badly jointed to risk trying it.
You could train a dog to cut a worktop. Nothing hard about it.
Just remember to always cut INTO the postformed edge which means you have to cut some joints with the worktop up the right way and others with the worktop upside down. If you don't it will flick the formica off the edge. Just think about it.
Use sharp bits and do each cut in 3 or 4 passes about 10mm depth at a time. Too much depth in one pass will burn your bits and blunt them.
If you do try this I would first try on spare bit of worktop, you will need jig,new router bit ,worktop clamping bolts ,colour fill for the joint and about 2 to3 hours
Am going to practice on some scrap bits of wood 1st before attempting it. Messed up on the price of the bit ib the qoute already. Didn't realise they were ÂŁ25!!
Thanks for the vid. I think there was a video for the unica jig which someone put on here. It was very good
Did my solid oak ones easy even a recess for Belfast sink with drop beads. It's a time consuming process.
1/2" 1600w router with new cutter for each joint.
Jig - screw fix ÂŁ65ish
Few clams
Worktop jointing things - I also used biscuits and resin glue.
Follow instructions on jig.get right collet.
U start at side of hole in jig furthest from finished face, left to right or right to left cut no more than 7mm depth at a time. Once through drop router to full depth then go against face side of jig in one slow and steady swoop. The collet (guide bush) is 2mm smaller than the hole in the jig. As you gradually cut through u will leave a rough edge 2mm too long, the full depth cut removes the final 2mm and gives a razor sharp edge.
12mm straight cutters are cheap enough in boxes of 3 a wicks. Buy router from b&q use it then take back with an intermittent fault and get a refund!!
Mine didn't hobnobs made a right mess!
I'm just glad I had brown worktops otherwise the chocolate digestives would have ruined the joint.
When I say I wouldn't do it, I meant I wouldn't be happy to take anyone's money for it. I'd try it out on my own house no problem.
Few clams
Take it back. He he
Be a man and make your own jig out of MDF, my brother did. Well okay, he is a joiner and the most I've ever done with a butt and scribe joint is tighten the bolts. Takes a bit of skill that job but is something to be proud of when you run your finger nail over the join and can't feel or see a thing.
10mm ratchet spanner makes doing the bolts up a piece of cake remember to colourfill the joint or use a bit of clear silicone before nipping up the bolts, biscuits make for better joints and as has been said before cut into the edge and use a new router bit in a couple of passes
Reply to kiychen jig routing video in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
B
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper...
Sonya K
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
