Discuss initial flush after work to remove flux etc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
aviator99_uk
Hi Guys,
I have just finished doing some major mods to an existing system which is mostly copper for the htg and a couple of lengths of Hep20 on the DHW F&R.
I have used mostly normal copper connections, led free solder, fernox flux, and some Tectite (discrete heat).
Need to flush the flux residue out of the system as I know some fluxes can cause corrosion and I suspect some could affect the Hep20, don't believe it needs a power flush as it already had a sludge filter etc.
What chemical? How?
Cheers,
Ag
welcome to our forums.
i normally use a bottle of h2o
I was expecting something like; fill it, add some magic smoke, run it, drain it, fill it, run it, stop. :confused:
The magic smoke must be important because when we let the magic smoke out of our telly it stopped working...................:D
Reply to initial flush after work to remove flux etc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
