Discuss ideal logic + in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
fatherof2
i fitted an ideal logic+ 30kw for a customer last year and got a phone call last week from the customer telling me there was a constant humming noise coming from it in the loft ...popped round to take a look and found the pump running continually, not much i could do about it as it was still under warranty so called ideal in the morning. turns out there's a fault with a link on a batch that went out last year.
just a heads up if anyone else gets this problem
just to add ideal were..well...ideal :biggrin5: engineer turned up first thing next day and corrected the fault all under the 5 years parts and labour warranty
Thanks for the heads up matey.
They had a bad batch of boilers a few years ago - they are called the ICOS/ISAR
LOL - ****ty boilers ICOS/ISAR....
Logics seem pretty ok upto now tho, only heard a few things going wrong but thats expected of all makes/models.
put a fair few in for customers and this is the only issue i've ever had
i know but look after lots of icos ,well known i hate them but not as bad to work on as worcesterIMHO and i hope they sort themselves out they are british after all
worcesters aren't all that but not as sh*t as ferroli :icon10:
ferroli domicompact gas valves are a pain.
You seen/worked inside a Logic yet GasMan?
Reply to ideal logic + in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I...
My heating system comprises an Ideal Logic 12 boiler located downstairs and a Gledhill OV SOL cylinder located upstairs . The problem is that when...
E
Have an Ideal Logic + 18 with intermittent fault. When on demand the display constantly changes from O to C but burner doesn’t start. Can fix by...
Ideal Logic Heat 15 System Boiler Hi. Just started to get an F3 Fan Fault on this boiler. On power up there seems to be a quiet thump from...
Deleted member 120897
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just...
