Discuss Help needed on Ideal Logic Heat 15 System Boiler showing F3 error code in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi. Just started to get an F3 Fan Fault on this boiler. On power up there seems to be a quiet thump from somewhere then it goes through the start up sequence. It spends a few seconds on the ‘c’ display before coming up with the F3 error code. Can anyone advise checks I can carry out to identify the problem. This is a system boiler so the pump is upstairs with the water tank. Thanks for your help
Reply to Help needed on Ideal Logic Heat 15 System Boiler showing F3 error code in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
