Discuss How long can I leave in Sentinel X400 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ABB
Hello,
I’ve got a build up of sludge in my system so wanted to run a cleaner through. I have a magnaclean fitted so was hoping to add Sentinel X400 to the system and leave it in indefinitely - just cleaning the magnaclean weekly for a few weeks until it runs clean rather than draining/refilling system.
In theory is there any problem with leaving X400 in the system indefinitely? If so is there any other product that will do the job I want and can be left in the system permanently?
Appreciate any advice.
Hello,
Call or email Sentinel is your best bet.
Just read the instructions:
https://www.sentinelprotects.com/si...t-sheets/sentinel_pfs_x400_uk_v5_jan_2019.pdf
This says that you can leave X400 in the system indefinitely but it only keeps the sludge in suspension for 3-4 weeks, i.e. for full effectiveness you need to drain/flush and refill with clean water and inhibitor within that period.
The problem with your no-drain/magnaclean approach is that not all the components of sludge are magnetic so they'll stay in the system unless you drain.
Reply to How long can I leave in Sentinel X400 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
