Discuss How do you hang a radiator on a crumbly/lath plaster wall? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dreading going back tomorrow and facing that bloody wall. Its not lath its like the plaster you get on it that just falls appart. Its external so must be some kind of crap brick. God knows how they made them in the 1930s
Could I use that my finger sized hole?http://www.NoLinkingToThis/p/fischer-fis-v-hybrid-mortar-resin-360ml/88507
I have used something similar to the above and fixed threaded rod into bricks before and then just drilled out the holes on the bracket and secured with nuts. That was to hang a 600x2000 K2 on a crap wall. Not had a call to say its fallen off so assume its still going strong 5 years later
And there was the customer thinking its a 60 quid jobI had one that partitioned into a cupboard on other side of wall.
Wall was just falling apart.
Multi tooled into the back of the wall and put internal battens in. Cavity foamed the incision, cut it back once dried and skimmed over.
Whats Portland, a rapid set cement?This may or may not help but it's worth a mention.
Clear a good sized hole in the plaster ( fist size). Clear out all the loose debris and drill into the brick/stone, to give a good 2"-3" depth.
Fill that hole ( pushed in well and filled level with plaster surface). With a mix half Portland and half bonding.
It will set fairly quick and give you an iron like material to drill and plug.
No, normal bag of cementWhats Portland, a rapid set cement?
Reply to How do you hang a radiator on a crumbly/lath plaster wall? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
