Currently reading:
Best way to fix a rad to a tiled plasterboard wall?
Discuss Best way to fix a rad to a tiled plasterboard wall? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
arran197
I go to loads of radiators at work that have fallen off the wall due to the installing thinking it is ok to install a 1100 x 500 double panel radiator with 2 plasterboard fixings per bracket.
Anyway, last night I went to my fiance's aunty's house because the radiator was leaking. The rad has a small hole in the bottom, so I will need to fit a new one. But the old one just has a 2" 10 and a brown plug in the plaster board, which I don't really want to do. But the wall is tiled, so it is going to be difficult to use expansion screws and red heads are not going to work either. I am thinking I'm going to have to drill out the tile to the size of the head of the expansion fittings.
What are your thoughts/experiences/suggestions?
I always get a good fixing to tiles with brown plugs and 2" 10's.
If you are worried about getting a good fixing silicone the back of the bracket. Once it sets it will never come off
Just been looking at those Fischer plasterboard fixings, they look like they might do the job. The other ones are the ones I would normally use, but the problem is that the tiles won't allow the part showing to fix in the plasterboard. So I need something to fit in the wall.
I did'nt *** it out, for some reason its done automatically when you post a link. The hollow wall anchors can be used on tiled walls but you need to snip off the two pointy bits that would normally dig into the plasterboard and they're best put in with the special tool http://www.*************/p/rawlplug-setting-tool/92462 i think you know what to do now.:smile5:
Ha ha, ye cheers Ian. A guy I work with has got one of the puller things. Might be worth me investing in one I suppose as turning the screw heads is a bit of a ball ache! Lol! I did fancy giving those plugs a go, not used them before and the reviews of them seem quite good. But they are nearly £7 and I will only use about 8! Lol!
Do you buy a lot of stuff from screfix Ian? I am thinking of getting the rad from there too, £28. Do they put the height or width measurement first?
it's probably worth buying yourself a box of em, i always do as its not just rads they come in handy for. I tend to shop around for my stuff and sometimes Screwfix fits the bill. Yes i've had rads from them but will generally collect them from the local depot which is only 15 mins away, had too many bad experiences with damaged mail order rads.
liddl did a complete box of various daisy bolts and fixing tool for £15 a few weeks ago.
knew i should have bought one!!!.
gripfill the bracket to the wall then any fixing will do.imo.
Been and got one of the setting tools tonight, so will use what I have already got and try it. If it doesn't work I will bite the bullet.
Been and fitted the radiator today, the setting tool worked, but it kept pushing out at the sides, had to use my grips to crush it back together?
Having said that, the brackets were well and truly fixed to the wall, I don't think they'll be coming off in a while! Used a wood drill bit on the tile at first, to take off the shinny top layer and then a masonry bot, not on hammer, gradually getting up to a 10mm (the biggest I had). The fixings recommend an 11mm, but I think tapping them in slightly is better than having them slide in with ease anyway.
Thanks for your help anyway people.
Reply to Best way to fix a rad to a tiled plasterboard wall? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
