Discuss how do i fit dishwasher hose onto a 15mm self cutting isolating valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
craighx
I purchased a new dishwasher recently, thinking that there was a cold water supply i could attach to. Unfortunately, there was only 1 supply valve which was being used by the washing machine.
So i had to create a new supply.
I purchased a self cutting 15mm isolating valve but the end of the hose (standard size) is too wide to screw onto the isolating valve.
I have searched all over for adapters so i can screw a standard supply hose onto end of isolating valve.
So how do i attach the hose to the valve.
The screw end of the valve is 18mm wide and the diameter of the hose is 27mm so i need something to either screw into the hose (ie with screw on either side) or something to screw onto valve so i can tightly attach + screw the two together.
i think that's how i could fit the two together
any1 know where i could get double side thread screw to do that
or any other advice on how i can fit hose to valve when its wider than valve end ?
You can buy a Y peice to convert the outlet of one valve into 2 outlets or get a lov
cal plumber in to fit another valve
Ecowarm it's an Ultima Abacus 15mm self cutting valve. Ultima and Abacus are the names on the packet it came in. I bought it from bes.co.uk. Here is the link to it
Isolating & Service Valves
Quality
Do you mean buy a Y-piece to fit onto the existing water valve so I can use both the washing machine and dishwasher on it ?
If not then how do I do it with 15mm iso valve :-
How do I connect a Y-piece to the isolating valve ?
Do they just screw on ?
What size Y-piece would I need ?
It's a 15mm self cutting valve Isolating & Service Valves but the end with the thread I need to screw onto is
18mm wide.
And if a Y-piece has two outlets (which it would ofcourse lol) then how would I stop water coming out of the outlet I'm not using if
I was connecting just dishwasher to the isolating valve ?
You bought a 15mm self cutting isolation valve but you needed a 3/4" self cutting washing machine valve as linked above byb ecowarm. Actually you should have a proper soldered/compression fitting and a washing machine valve as the selfcutting ones sometimes don't produce enough water for the machine and not the most reliable connection.
But if you're doing it yourself and don't have the ability to do that what you should do is buy a 1/2" compression blanking cap and 1/2" fibre washer and while properly supporting the current installed valve with some grips/a spanner screw on the cap with fibre washer inside and tighten roughly half a turn past finger tight. Turn on the iso and make sure it's not dripping. If it is tighten a little more. Even if it appears dry, dry it thoroughly and give it a few minutes and then press your fingers around it to make sure no dampness has appeared. If all good turn the iso back off.
When you've done that insall the 3/4" cutting valve exactly the same way you did the 15mm valve. When you attatch the hose, get it finger tight and the with grips just tweak it an extra 1/4 turn.
I don't like the Y pieces in general because if you end up turning both appliances off, taking off the Y piece and re-connecting the working appliance.
Also these self cutting things over a period of time don't allow enough water in. I'd cut into the pipe work and put in another proper fitting.
It won't cost the earth to get a plumber in to do this.
I've bought a Y-piece now, so I'll see if that allows me to connect the two appliances.
If not I may try a 3/4 " valve but will probably just call in a plumber.
I know it should not cost much but I paid for delivery + installation of dishwasher and the delivery guys said it was easy to fit a new valve.
My money is tight and I was just trying to save a bit when I can't get a refund for the installation not being able to be done.
So I'll try the Y-piece when it arrives and I may buy a 3/4" self cutting valve if it doesn't do the job
( I could only find 15mm 1s in internet searches) but I'll probably call it a day and call in a plumber. Thanks for all of your help.
I come across this a lot. People buy the installation because its relatively cheap but the people who come out fail to connect up the new appliance 'a lot'
1. The valve doesn't turn off
2. The waste doesn't fit
3. Hose isn't long enough.
4. No Y piece and the water doesn't turn off.
Argue with them you'll get the refund of fitting it.
I love the fact the installation guys aren't allowed to do anything other than connect to pre-existing and working valve. I've had loads of easy jobs out of it.
Reply to how do i fit dishwasher hose onto a 15mm self cutting isolating valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I have to replace the taps on a small sink. Currently the tails fit onto the hot and cold-water supplies into a female end fitting. I want to...
A
Hi, I am trying to fit a replacement tap to a mini-sink that's built in to the top of a toilet. The original tap isn't made any more by the...
Hi, some advice would be great. I have an Instinct Eco-Mag fitted and it has started to leak from the port that the magnetic tube is removed from...
Hi, I have an issue with the standpipe trap in a 3-year-old flat. This flat came with a fitted dishwasher that has been completely unused for that...
