Discuss Hot Water tank filling too slowly in the USA area at PlumbersForums.net
Hi, looking for some advice about a hotter tank that is filling too slowly from the header. The tank drains when the shower is used. Do I need a bigger tan or can I fit something to stop the tank draining totally ? Thanks in advance . . . Taylor
Any pictures of your hot water cylinder and tank ?
If this is a new problem, I suspect you just need a new diaphragm in the ball valve - or someone’s partially closed a valve somewhere.
Which Island? I’ve just spent a week on Barra - absolutely beautiful.
If your draining the tank larger or second tank required.
Just make sure ball valve is working correctly before doing any other work.
Any idea what your mains flow rate is?
Thank you for coming back to me ... no idea what the flow rate is but we're on a low pressure supply. Bigger hot water tank might the the best solution but could still technically be drained recreating the problem !
Reply to Hot Water tank filling too slowly in the USA area at PlumbersForums.net
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot...
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
First post as I can not figure this one out. I have a hot water boiler heating system, gas fired, with an HTP SuperStor indirect hot water tank...
