Discuss Hot Water tank filling too slowly in the USA area at PlumbersForums.net
Hi, looking for some advice about a hotter tank that is filling too slowly from the header. The tank drains when the shower is used. Do I need a bigger tan or can I fit something to stop the tank draining totally ? Thanks in advance . . . Taylor
Any pictures of your hot water cylinder and tank ?
If this is a new problem, I suspect you just need a new diaphragm in the ball valve - or someone’s partially closed a valve somewhere.
Which Island? I’ve just spent a week on Barra - absolutely beautiful.
If your draining the tank larger or second tank required.
Just make sure ball valve is working correctly before doing any other work.
Any idea what your mains flow rate is?
Thank you for coming back to me ... no idea what the flow rate is but we're on a low pressure supply. Bigger hot water tank might the the best solution but could still technically be drained recreating the problem !
Reply to Hot Water tank filling too slowly in the USA area at PlumbersForums.net
