Discuss HOT WATER Problem Help!! Needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
hiretools
Good Morning fella's. I have noticed over the past couple weeks a humming noise in the hot water pipe work. This occurs every time the hot water tap is put on either in the kitchen or bathroom. To rectify the humming noise I have to turn on the cold water tap in the bathroom and the humming noise sub sides. It is not just when the water is hot but also when the hot water is tepid due to not putting the h/w cylinder on. My system is a vented gravity fed system. If you have any idea's it would be gratefully received. Hiretools...
Try changing the tap washer to see if that fixes it, if not, let us know.
Sounds like water hammer to me. I'd be looking at the float operated valve in the cold water cistern first.
Re-read it. Looks like Mike might win this.
Reply to HOT WATER Problem Help!! Needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
In our sealed Megalo system, when hot water tap is used (say in bathroom shower) the megaflo is taking in some fresh water, I guess to compensate...
