Discuss Hot blow torch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stani
Subscribed
There was a thread a while ago regarding a blow torch, just seen it in Stax (for those that have one near them) £25-99 +vat
Look's o.k and a good price anyone used one?.....regards Turnpin:D
The only downside at the moment I can see is max op temp 1630 c when mapp runs around 2/2300 c
Propane also burns in air at a little less than 2000c, forgive me but I don't quite see the point of that operating temp warning especially when they have a plastic bodied piezo sitting quite near the tip.
Did they have any similar torches without the piezo?
No that was the only type, I might get one as a spare, my sf2 is good but anything happens I'd be lost. So might be worthwhile just keeping it.
Worth it I think, I've used one before and as you hold the gas bottle I found them far easier to handle than our gun style torches like the Roth.
If you're going to get a budget spare you won't do much better than the £40 from 'stool'station. I've been using it 6 months and really like it.
It's a Bullfinch under a different name as far as I can make out.
This one.
ezo Ignition Turbo Torch
Catalogue p117
Catalogue 117Piezo Ignition Turbo Torch
Uses MAP-Plus or propane gas, 71066 or 13125 with self-lighting piezo ignition. Ideal for most soldering applications. High performance adjustable turbo action flame with safety lock to prevent accidental ignition and button lock for continuous use.
Code For delivery
36574Piezo Ignition Turbo Torch 24 Each
£39.81
£33.17 ex.
Remove
Reply to Hot blow torch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
