Discuss Holding a 3 port valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
X
xtremeo
Hi is it possible to hold a vaccum with bungs and change a 3 port valve, and it is 3 openings and I believe you can only have 2 openings, if not does anyone have any other solutions without draining down, or any other tips.
thanks
Hi pipeworks a nightmare possible airlocks, what's the the best freeze kit to buy.
Electric are best but only two freeze heads. Are there no isolation valves/pump valves nearby so you can just freeze the legs to the heating and hot water circuit? Hiring a machine is the best bet. I have done it on problematic systems with freeze spray but only in outbuildings with oil boilers where a bit of water is not too much of an issue. If you can isolate the flow to the 3 port valve you could try bunging it. I probably wouldn't try it in an airing cupboard though!
Can be done but not if you're not confident. Hire an electric freezer for the day. No stress no rush
Hi thanks for that what's your opinion on rothenberger co2 kit rofrost , lot cheaper than electric thanks
the problem with the co2 kits is you need to work fast as once the gas runs out well you know the next bit
you can hire the electric ones for about ÂŁ50-80 a day
My thoughts on the CO2 kits take me back to the video I watched earlier with a fella in a flat flooding the place. With an electric kit you leave it on and have no worries. If you have a local Williams branch they hire them for about ÂŁ35 a day if I remember right
Trade only mate
Reply to Holding a 3 port valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
