Discuss Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I’m using this simple set up to make sure my shower mixer pipes are not going for a walk.
One problem with that the tiler has to take it off to fit the tiles
I’m the tiler. You let the bonding plaster to set first and then get on with tiling. No probs at all.
faulty expansion vessel? not got a spare or time to go collect one, or cant do the job til next week......
drain upstairs, refill system bleed all rads apart from one(spare room, landing,bathroom) this unbled rad becomes your temperary expansion vessel.
you get to charge for the temp fix and again for the replacement!
now thats a top tip
It's going to be full of air... As the heating heats up, it compresses the air in the radiator and that takes the expanded water. It only lasts a week or so though.How does it work?
Keep the rad turned off? If you turn it on won't it just refill?
What am I missing?
yes,did happened to me ,but luckily it did on ground floor were concrete floor ,ever since new valves !!
Reply to Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
