Discuss HELP! - Worcester Bosh 24CDi - no pressure & cannot refill manually in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
julesij
Ok so I am not very technically minded - sorry :( so here goes. . .
My boiler has been losing pressure for a while - lost the lost 2 nights ago to 0 but seemed to refill itself. However, today 0 agin & no hot water - steam comming out of the top of it when you put the H/W tap on? I have tried to follow the instructions & turn the filling key "anticlockwise" but can do this forever with no change - it just goes round & round. Turn the grey key & water comes out. turn it on/off & nothing happens - just stays on 0.
Any idea of what is wrong with it? Does this need a plumber / new boiler as £ very tight (have home emergency but no service history - or if we had not sure where it is) in the throws of a DV here - so trying to sort it myself :(:(
Thank you JJx
You may need a new pressure relief valve fitted if pressure keeps dropping.
if its blowing steam out of the aouto air vent, then its possible the pump is knackered.
Thank you all
I will get a plumber to have a look at it in the week as it just ran dry by itself overnight, but it just helps me in the meantime - decorating so need hot water.
Thanks JJ
Reply to HELP! - Worcester Bosh 24CDi - no pressure & cannot refill manually in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. Today I have installed a new radiator upstairs. A little bit bigger so I had to make new pipe work. Before that I flushed as much water...
Hi all, I wonder if someone can help. We have a Worcester MT10 combi boiler that has a fault with the expansion vessel. The landlord is having...
Hi everyone, New here & my first post! I have a Worcester greenstar 24i, it is a conventional boiler, it has a water tank upstairs. For the...
2K
Hi, Have a Valliant Ecotec Plus 637 system boiler that is showing no error codes and S.0 (no demand for heat), but it is not heating. Have...
Dear All New member here, coming looking for help. A few weeks ago I had work carried out by a British Gas Homecare service technician. It...
