Discuss Help - Blanco 5300 mixer tap - spout failed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
emeraldbugle
Just had a fountain in the kitchen!
We've taken off the spout, can someone tell me what the piece at the bottom of the spout is called. I assume this is the piece that has failed.
Do you think we can get a spare or will we need to contact Blanco?
Should the white plastic bit be split vertically? I can't tell if this has split or is how it should be.
If it is just the o rings, how do I get the bottom bit off, again I can't tell if the metal at the bottom is part of the spout!
Reply to Help - Blanco 5300 mixer tap - spout failed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
