Discuss glowworm flexicom combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
buckley plumb
been to another of these where the filling loop valves are passing and the boiler pressures its self up to mains water pressure .this is the 3rd in the past 6 months .the valves and the filling loop pipe amount to £185 this is mad . last one i capped the flexi and one side of the valve and fitted an ext loop .glow worm should make a kit to blank off the loop so an external can be fitted.
Is it me or is the quality of all the boilers going down hill. Just been to a three year old Vaillant with knackered flue seals mixing the combustion air.
Reply to glowworm flexicom combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
Hi everyone just checking if this is right regarding water pressure and combi boiler pressure: Do hot and cold water always vary in pressure such...
Last summer I used one of those kits to fit an external tap , all went well , still good , its one of those flexi pipe , self cutting tap jobs ...
Hi everyone, Just a query about what size in KW gas combi boiler do I need for a top floor flat (3rd floor). I have a Vokera Easi heat plus...
1K
We had a Gloworm Energy 7 30r Boiler fitted in Jan 22 to replace a British Gas Boiler (which was a Glowworm Rebranded ) when the heat exchanger...
2K
