Discuss glow worm 18hxi F1 fault help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I have a glow worm 18 hxi keep getting F1 fault some times it will run and work fine.
The next time it will go to start up the green light comes on for 3 secs and click click click
light goes out and F1 red light flashes. you can turn it on and off 10 times then it will run fine. until the next time it wants to heat up the water or radiators.
any advice Many thanks
Get a gas safe registered engineer to come take a look. Where do you live? Someone on here might be able to help
Reply to glow worm 18hxi F1 fault help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Went to a customer today their glow worm Ultracom 24 HE goes to fire up then cuts out turning the heating pump off, then does the same again...
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Morco feb 24ed3 has a f1 fault code. The burner reading is fine. The fault is intermittent, sometimes the boiler won't ignite on either hot water...
I am looking for some basic advice please My house is on two floors, approx 240m2 and a spacious loft with good headroom and access. Glow Worm...
1K
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I...
1K
