Discuss General advice and also extras on CP12 in the Australia area at PlumbersForums.net
Hi everyone
I have been working as a gas engineer as a boiler installer for the past 5 years and recently I’m getting into doing landlords gas safety certificates. Any advice on faults which I can rectify (stuff to keep in the van) to increase my bill would be great! Also any general advice would be great as I haven’t competed a cp12 in quite a few years!
Many thanks
Hmmm fitting boilers for 5 years you should really complete a gas safety cert for each Installation it's in the regulations you need to keep a record of all the gas work you carry out that is everything service , repair , alteration and all new work digitally or paper copies if you get inspected by Gas Safe then you need to show them your records ,Things to carry smoke matches , smoke pellets , case seal , high temperature silicone , fire cement various heat exchanger seals , leak detector, warning notices and pad , caps and blanking meter discs, faults really depends on what boiler manufacturers boilers you work on minor internal leaks are a issue o ring seals AAV ' s in particular , self drilling screws for flues which are often not fixed , undersized gas supply pipework is a common fault and can be ID if a gas cooker or hob is fitted without a FFD you need 2 form of measuring gas pressure one at the appliance one at the meter, a good quality flue gas analyser and printer various apps and boiler manuals pdfs downloaded on your phone . Cheers kop
Brilliant thanks mate
Reply to General advice and also extras on CP12 in the Australia area at PlumbersForums.net
My daughter lives alone in a 3 bed semi in the west country. The house is 20 years old. The central heating and hot water are provided from a...
Hi, I’m looking to retrain as a gas engineer and do a new entrants gas course. I’m a bit concerned by the ‘on-job’ work experience/shadowing, as...
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I...
Hello everyone, I'm facing an issue with my Vaillant EcoTec 832 boiler and would greatly appreciate your expert advice. The Problem: Heating...
